Move AssignToProject to first page in NewItem Dialog
Hi we are usign TC11.2,
We have a scenario where we want to push AssignToProject to first dialog in New Item Dialog. We want to do it with configuration only
Re: Move AssignToProject to first page in NewItem Dialog
I dont think its possible by configuration,
but below things you may look at,
1. Create custom property named "Projects"
2. Add this property in operation descriptor of the your custom objects, and make it mandatory and visible
 so that it will be visible on item create dialouge.
3. Create custom LOV, which will have all projects in your organisation as values of this LOV.
4. Now one the project user has to select while creating the Item,
Now here you will require the customization for mapping this project value in Assigned project property.
Hope you get the idea.
registed an ER with Siemens. Thanks for sharing information
