NUMBER OF FILES IN THE FOLDER IN TEAMCENTER
Dear All
I have any question about number file in the folder.
How to know the number of file in the folder in Teamcenter 10.1
Thank you
Sudikin
Re: NUMBER OF FILES IN THE FOLDER IN TEAMCENTER
Sudikin,
I found a long winded way to see how many files / items exists in a folder.
1) Select a folder ( in my case, i have a few items and datasets in a folder).
2) Click on the Details View.
3) Select a item / Object in the details view, and click on the Exports Object to Excel icon.
4)Export to Excel dialog box appears and make sure you select Export All Objects in View as shown.
5) Click ok, This will export the Object Name, Type, Owner, Group and Date Modifed, Checked-out and Release status coloumns. You can customize the coloumns as well.
Hope this helps !
Cheers.
Teamcenter 10.1.7
TC Visualization 10.1.7
NX:11.02 | NX 9.02 | Catia V5 R2012 | AutoCAD 2018 | In-Context Editor |
Another way to do it is to select everything in the folder and click Copy. The numbers of objects on your clipboard will be shown (lower left corner of the rich client).
Best,
/Randy
Evaluating: AW 3.4
A more robust method utilizes the Teamcenter Multisite Assistant tool (MSA) (GTAC download):
tc_extract_msa -u= -p= -g= -rt=folder -list -folder=<unique_folder_name>
Tip: You can use the same tool to create folders and to populate a folder with Items.
Best,
/Randy
Evaluating: AW 3.4
In TC 10.1 if you RMB in the clipboard area, You can select Show Child Count Information and it displays the number of objects contain.
PS: Looks like somebody answered this question in another thread. Could somebody mark this as answer, for the benefit of the community ?
Teamcenter 10.1.7
