NX 10 and Teamcenter
I am having some issues with using NX 10 through Teamcenter.
when I edit the arangements it changes all the arrangements
When I try to create a new part, the XRX model and drawing templates to not show up.
When I use NX through my desktop I have none if these issues. Does anyone know wth is going on?
Re: NX 10 and Teamcenter
The behavior should not be any different between native or managed NX.
How are you editing an arrangement such that all arrangements are changed? Are you moving a component? Is that component independently positioned or "same position in all"?
If templates are not displayed when creating a new part in managed NX, then it's quite possible that NX templates have not been imported into the database.
Regards, Ben
How would I go about importing templates into the database?
