NX10 start manager error
Hello
Can anyone tell me what this error means and how can I troubleshoot itCapture.PNG
Re: NX10 start manager error
It means your TC-NX integration is not pointing to correct NX installation. I guess you have not installed TC-NX integration beacuse it is pointing to
a weired path. Open nxmanager_portal in notepad and check that value of  "UGII_BASE_DIR" is pointing to correct NX instalation path soemthing like:
your set UGII_BASE_DIR=C:\PROGRA~1\Siemens\NX10~1.0
Anshu
The path isn't weird, it's abbreviated
C:\PROGRA~1\UGS means the first folder in C: starting with the string 'PROGRA'
This will usually be C:\Program Files\ or C:\Program Data\ if it exists
Last (on 64-bit systems) is C:\Program Files(x86)\
This means the folder referred to is likely C:\Program Files\UGS
Hope this helps,
Thomas Musters, Virtual Reality development for Design & Engineering, ASML
Production: {NX9, VisMockup, Unity}
Development: {C#, Java, VB} Testing: {-none-}
