No Checkout History!
Any idea why all of the Items are not showing any Checkout History?
Is there a way to turn this on and off?
Thx in Advance!
Re: No Checkout History!
Below preference seems to have effect on checkin-checkout history. Try setting different values to see if it helps.
TCDefaultKeepLimit
Determines the number of sequences the system maintains as an item revision is checked in and out of the database. Sequences are subrevisions of item revisions that document the content of a revision during its evolution. Checking out an item revision increments the sequence ID. At logon, the system automatically removes the oldest sequence when the limit specified with this preference is reached.
Valid Values: Accepts a single string as a value. Must be a single, positive integer more than zero.
Default Values : 3
Did you try
   Select any object
      right click
          goto - Check-In/Out >
                       Checkout history
Venny
