Object used in previous versions of an item
I have a item that I want to delete, but this item was used in a previous version of other item. Now in the impact analisys view, it shows it as used in the assembly item but it is not anymore. How can I delete it?
We use NX11.0.1 and TC11.2.3
Re: Object used in previous versions of an item
The item you are trying to delete, Does it have any CAD dataset that is used in assembly? If yes, then you have to remove it from CAD assembly also. Removing item only from structure in Teamcenter will not work.
It had the 3d model dataset used in assemblies, but I removed it from the assemblies. I think that the problem is that TC stores old versions (not revisions) of the assemblies and in the old versions, the dataset of the part is still used.
