Opening DWG files on Teamcenter
Hi guys,
Can we open DWG/DXF files on the Viewer in Teamcenter?
Cem
39 REPLIES 39
Re: Opening DWG files on Teamcenter
The site preference defaultViewerConfig.VIEWERCONFIG need to have values added to handle the image types you require. For example for the embedded viewer to view drawing, CGM, Tiff & PDF files, we added the following values. Site Preference: defaultViewerConfig.VIEWERCONFIG Values: Image.TCTwoDViewer=Image,CGM_Reference FGA_PDF.TCTwoDViewer=PDF_Reference,PDF,acrobat CGM.TCTwoDViewer=CGM_Reference FGA_Tagimage.TCTwoDViewer=tagimage DrawingSheetProxy.DrawingViewer Drawing.DrawingViewer
I also did that but what should we enter to cover DWG files?
Cem
I was wondering if you ever figured out how to view dwg files in the viewer?
Jake
Nope :)
Best Regards,
Cem ALPAY, Managing Partner
UCGEN YAZILIM LTD. STI.
TEL: 0216 550 52 06
Siemens Genius Siemens Genius
Siemens Genius
Hi Cem,
Try adding the following value to the Teamcenter Preference: defaultViewerConfig.VIEWERCONFIG
Preference Name: defaultViewerConfig.VIEWERCONFIG
Value: DXF.TCTwoDViewer=DXF
Arun Kumar G
What about DWG?
Can it be done like the same?
Saygılarımla,
Cem ALPAY, Yönetici
ÜÇGEN YAZILIM LTD. ŞTİ.
TEL: 0216 550 52 06
[cid:image001.jpg@01D1F9FC.A6391A50]
Siemens Genius
I'm not sure but try adding another value DWG.TCTwoDViewer=DWG, {"Reference" from Drawing dataset named Reference)
The files I would like to view are acutally .qaf.  It allows you a very small preview on the summary tab, but I want to see a larger image in the viewer.  Our current work around is to convert the qaf to pdf to see in viewer.
Jake
Hi Jake, try these:
qaf files:
UGMASTER.TCTwoDViewer=UG-QuickAccess-Binary
UGPART.TCTwoDViewer=UG-QuickAccess-Binary
dxf/dwg:
ACADDWG.TCTwoDViewer=DWG
Regards, Ben
NX (v17 - 1872) | Teamcenter (9 - 12)
