Re: Opening DWG files on Teamcenter
Set the License Level to "Mockup", run the registry (genregxml.bat) and restart RAC.
Ben
NX (v17 - 1876) | Teamcenter (9 - 12)
Ben,
The Value "UGPART.TCTwoDViewer=UGPART" works beautifully for viewing NX drawings. Thank you
Are you aware of any values that might allow you to view Pro E drawings in the viewer?
-Jake
Jake
Not sure, sorry. The syntax is <dataset type>.<viewer type>=<list of named references>
I would start with that. Perhaps someone else in this forum has figured it out, if it's even possible.
Ben
Honored Contributor
Honored Contributor
Tc version 10.1.2
-Dave
NX1867(if it had versions) | Teamcenter 11.6 | Windows 10
@DaveK, the same should be true for you.
I suspect your PortalViewer_License_Level is set to 'Base' in client_specific.properties. Set it to 'Mockup', run genregxml.bat and restart RAC.
Ben
Honored Contributor
Honored Contributor
Is this a server side thing?  my Tc speak still isn't that great, and you lost me on that :)
-Dave
Yep, it's server side.
%TC_ROOT%\portal\plugins\configuration_<tc version>\client_specific.properties
# Runtime and custom entries below this line
PortalViewer_Cache=
PortalViewer_Optional_Licenses=
PortalViewer_License_Level=Mockup
%TC_ROOT%\portal\registry\genregxml.bat
Ben
This conversation is very good and I hate to interrupt it. However, client_specific.properties is on the client side. You'll find it in PORTAL_ROOT (where you installed the rich client) then either \portal (TEM) or \rac (OTW). Followed by \plugins\configuration_<tc_version>\. You'll also find site_specific.properties in this same directory. You're doing great ... keep up the good work.
Evaluating: AW 3.4
Thanks @RandyEllsworth :)
Honored Contributor
Honored Contributor
Would this requre downtime for Teamcenter?  ie should it be done after hours, to could out admin do it during the working hours?
-Dave
