PDF with Revision
Hi Guys.
When I search for a PDF and want to send it via email.  I noticed that the name doesn't include the revision.
Is it possible to set this as default in Teamcenter?
Re: PDF with Revision
Hello, hmm. I have a PDF dataset with a name that includes the revision id, did you mean it?
It depends on the CAD and integration used. For instance, some CAD integrations do not support adding the revision id. It may be possible and it may not depending on their CAD integration used.
Evaluating: AW 3.4
Betreff: PDF with Revision
It depends how this PDF is generated. You Admin can configure Dispatcher tu use or include the PDF creation within a workflow. However, at the end it is possible to add an attribute as a postfix to a neutral format like PDF.
Michael
Teamcenter UA | NX CAD
try to set dataset_saveas_pattern as per attached image and see, it helps
Hi Arthur.
If you want to send it via email, does the name of your file include the revision?
Hi Dazzie if you mean Envelope in Teamcenter, yes, it does.
Hi Arthur.
I need to aska stupid question, where is the envelope?
Hi Arthur.
I found my envelope.
It didn't work as I want it to.
If I send the PDF within teamcenter, the file does have the revision.
If I send the PDF to an external email, there is no revision.
Why is this?
write how you send pdf dataset to external mail
