PLM XML color settings?
assume there is a PLM XML referencing Jt files to represent an assembly.
Is it possible to do color coding of Instances using PLM XML? Goal is to open PLM XML file in JT2Go to show instances in different colors. I do not want to change color in JT files.
E.g
Assembly.plmxml
  Instance1 - Part1.JT (red)
  Instance2 - Part1.JT (red)
  Instance3 - Part1.JT (green)
Frank
