PLMXML Export via programming
HI,
I want to export MPP data from Teamcenter via a request to teamcenter given some parameters. I know PLMXML is an export option.
How do you programatically export data from TC to PLMXML?
Is there a SDK and where can I download it?
Is there guide I can read for the sdk?
Thanks.
Re: PLMXML Export via programming
I think you're looking for ITK (Integrated Tool Kit) and it requires a license. It's a C/C++ library that you compile to a DLL that's deployed to your server. The "guide" is included with TcHelp (Tc10.1.0_pub.zip) in tcrefs (tcrefs.jar\help\en_US\custom\ITKFunction\)
Evaluating: AW 3.4
Thanks. As I read over the document.
It appears ITK is being deprecatd in favor SOA clients (WSDL, .NET DLLs, JAVA RAR)
Does SOA have the ability to create PLMXML? If so, what service should I use.
Thanks.
