PLMXML_export Workflow
Within the workflow designer it's possible te export Workflows. I wonder if this is also possible via PLMXML_export?
Marcel v. Leusden
Re: PLMXML_export Workflow
Just use menu Tools>Export.
Choose required workflow, and file name. I will get you the xml file
S A Saravanakumar
CBE, INDIA
plmxml_export -u= -p= -g= -xml_file=<location>.xml -transfermode=workflow_template_mode -template=<workflow template name>
It will only do one workflow at a time. I've asked for ER to export all workflows at once with plmxml.
Jamie
