PLMXML export top level of multi-level assembly
I need to export just one top level of multi-level assembly using PLMXML without processing the whole structure that's huge. Is there an OOTB transfer mode to do this?
What closure rules should I use?
8 REPLIES 8
Re: PLMXML export top level of multi-level assembly
Didn't find any OOTB. Let me know if you need custom.
Hi @deepak12345,
yes, I need custom.
You dont' need custom dev. Simply, use the following clause in your closure rule to browser BOM Structure at first level:
TYPE:BOMLine:TYPE:BOMLine:PROPERTY:bl_child_lines:TRAVERS_AND_PROCESS:PRIMARY.bl_level_starting_0=="0"
you can try closure rule,If rev is not needed then you can leave that line.you can add requiured properties in property BOM_EXPORT.JPGset.BOM_EXPORT.JPG
Thank you @PhilippeB, I exported 1 level of BOM. But I couldn't import it. Can it be because of variant rules present in BOM?
Which transfermode did you use for importing? incremental_import?
Yes I use incremental_import.
What's wrong after importing? missing stuff or error messages? Please be more precise.
