Pro E Creo Assembly failed when child parts migrated to NX in Teamcenter
Hi All,
We are migrating some parts from Pro E to NX in Teamcenter by creating a new revisions. But reporting Pro E assemblies of migrated parts(which are also in teamcenter) are failing to load the child parts of original revisions. So is there any way to load Pro E assemblies in teamcenter fully with child parts of original revisions after migration?
Re: Pro E Creo Assembly failed when child parts migrated to NX in Teamcenter
Are you using Content Migration Manager (CMM)?
Evaluating: AW 3.4
No, We are not using Content Migration Manager. We are opening Pro E parts (from teamcenter) directly in NX and performing save as to new revision and start building it in NX.
Hi @pb_suhas,
ProE part files have the file extension as ". prt" which is same for NX part files. So it is not possible to know whether a file is created in ProE or NX. You have to create a new part file in NX and use File > Import > Pro/E so that part file or assembly will be imported into the current NX part.
Hi Ganesh_Kadole
We are migrating the Pro E parts in the Teamcenter to NX by creating new revision and retaining the same part number. Problem is after migration, respective Pro E higher assemblies which contains those migrated parts(Original Pro E revisions) are failing to load those parts. Apart from those migrated parts, all other parts are loading successfully. In NX also there are no issues.
