Problem connecting to the server
Anyone know how to correct this error?
thank´s
Re: Problem connecting to the server
What is your environment (O/S, Tc, etc. version/configuration)?
Is TAO running?
Is TAO started as service?
Have you already logged off and on again?
Have you restarted the system?
Have you cleared any of the Teamcenter cache folders of the user?
Employees of the customers, together we are strong ;)
FCC seems that the server does not connect, I tried to connect from the CMD with fccstat -start and connected, I have directed the well variale HOME is a new installation, alquien know it can be happening?
Thank you!
It seems like there is a Java process that is still connected to the server. Close your TAO windows/services (TaoImR), and end any Java processes running (make sure you close any other Java programs before ending the processes). Then try again to connect.
If the problem still persists you can clear your RAC folder. Where this is depends on your platform and installation. You can ask IT/Your Admin to help you with this.
