Problems with the manufacturing resource library (MRL) instalation in Teamcenter
Hi everyone,
I just started using the NX10 integration with Teamcenter 10 and we found out that we were lacking the MRL in teamcenter. We proceeded to install the MRL on the server and followed the steps provided by Siemens, since it is a new installation we selected "override existing data", confirmed the selections and gave the OK for the installation. However we obtain the following error for the "AdminClass":
We decided to cancel the installation and repeat it again ignoring the override command and obtained exactly the same error:
Does any of you know how to solve this error? Any help you could provide would be appreciated.
Thank you in advance.
Re: Problems with the manufacturing resource library (MRL) instalation in Teamcenter
Review the setup logs for more information located at C:\Users\TCINST~1\AppData\Local\Temp\MRL\. It looks like either the pax syntax may be wrong for id=4 or something from classification. The logs should help you learn more.
Evaluating: AW 3.4
