Programming access to Team Center (C++ .NET from Autodesk Inventor)
I use Autodesk Inventor to create assemblies automatically using C++ together with .NET. All .ipt and iam files are stored on the local disk of the user.
The company is now moving to team center. Is there any programming guide, or API, or tutorials about how to connect up to TeamCenter from Inventor programatically (.NET).
Re: Programming access to Team Center (C++ .NET from Autodesk Inventor)
You can use SOA API to integrate 3rd party softwares with Teamcenter. I'm giving below the link to TC documentation. Use "Services Guide" under "Customizing Teamcenter".
Apart from this, Teamcenter installation media contains soa_client.zip which contains project "HelloTeamcenter", a sample project as startup.
https://docs.plm.automation.siemens.com/tdoc/tc/11.3/help/#uid:xid1256877:index_plm00076
Thanks! Now the real work begins...
