Property renderer on release status
Siemens Creator
I was trying to add property renderer on the release status of a custom object. I used the following renderer:
<?xml version="1.0" encoding="UTF-8"?>
<icons Version="1.0">
<propertyMap name="StatusMap">
<item key="Released" value="A7tick.png"/>
<item key="Pending" value="A7cross.png"/>
<item key=" " value="A7release.png" />
</propertyMap>
<primaryIcon source="A7release.png"/>
<overlayIcon source="release_status_list" mapName="StatusMap" />
</icons>
However, the overlay action doesnot work properly. Any ideas???
24 REPLIES 24
Re: Property renderer on release status
Good afternoon, try changing the following lines:
to
<propertyMap name="ReleaseStatusMap">
to
<overlayIcon source="object_name" mapName="ReleaseStatusMap"/>
Siemens Creator
No it didnot work :(
Did you add icons to BMIDE? The names of your statuses correspond to the status names in BMIDE?
Did you attach the property object_string of the ReleaseStatus object to the property renderer?
I still do not like the line
<item key = "" value = "A7release.png" />
Try to remove it
Siemens Creator
I used the following property renderer : <?xml version="1.0" encoding="UTF-8"?>
</propertyMap>
<overlayIcon source="object_name" mapName="ReleaseStatusMap" />
</icons>
along with ReleaseStatus.object_string but it still didnt work
Do you work in Teamcenter in English?
Siemens Creator
Yes
Property Renderer only works against the object_string and no other property. The overlayIcon should be contained within the primaryIcon block.
<primaryIcon source="A7release.png">
   <overlayIcon source="object_string" mapName="StatusMap" />
</primaryIcon>
But I don't think you need the overlayIcon line for applying a release status icon? It can read like...
   </propertyMap>
   <primaryIcon source="object_string" mapName="ReleaseStatusMap"/>
</icons>
Unless you are truly trying to create an overlay for the release status icon then it would look like...
   </propertyMap>
</primaryIcon> </icons>
Attach renderer to object_string of A7ItemRevision
Evaluating: AW 3.4
Siemens Creator
Hi Randy,
I tried your process as well ... but I am still not able to get the overlay icons to work.
They work perfectly fine when I checked with 'checked_out' property however for release status I am unable to get the overlays to work! :(
Good afternoon, it's strange, when I did property rendering in Teamcenter 10 and it worked for me, but only if I used English, it did not work in other languages.
Have you tried pushing refresh or F5 on revisions and statuses?
