Query an Item to list datasets
I have been reviewing the Query Builder and trying to find an option to list all datasets to an Item/Item Revision.  I have various folders under the "References" which contain datasets also.  Is there a way to do this.
thanks
Paul
9 REPLIES 9
Re: Query an Item to list datasets
I guess the folders you mentioned are pseudofolders and that you then have datasets with different relations attached to the irem revision.
There is a hint in the query builder called "dataset with unknown relation to IR". If you follow the steps listed there you get a query where you can enter the name of the IR and as a result you get all the datasets attached.
xtof
Thanks for your input, and yes I have pseudo folders.  Is there a way to enter in the Item ID and then this would list all the datasets associated with the Item.
thank you
Paul
this should do it:2017-01-05 15_55_26-Tc11.2.2 AW3.1a Oracle12c internal - VMware Workstation 12 Player (Non-commercia.pngxtof
I tried your suggestion, but no results appeared.  I added this line in but it only lists the datasets under the Item Revision, but not any datasets under the References where there are other datasets are located (pseudo folders)
Thank You
Paul
This is what I understood:
2017-01-05 16_48_48-Tc11.2.2 AW3.1a Oracle12c internal - VMware Workstation 12 Player (Non-commercia.png
it looks like you still have itemrevision instead of item in your query attributes...
Sorry for the confusion.  Here is a image
thank you
Paul
The screenshot helps to understand the problem ;-)
But I have no good idea how to get the datasets from different depths of folder structure.
xtof
thank you for your time.  All feedback was helpful.
At least partial solved.
