Query to find items revisions under specific folder.
Hey,
I want to do mass set of properties.
It is possible by marking all objects want to edit and then by edit properties we can to this.
For items it is simple, mark and edit, but key point is how easy mark Items Revisions....
So i find a query witch is working well by showing me only items revisions. Good.
This solution is fine if you have specific property to filter by to catch only items Revision you are interested in.
My search property is folderSmiley Happy. How to display(find) only items revisions in specific folder? .ie:
Re: Query to find items revisions under specific folder.
If you already have a querry with the search class "ItemRevision" you can add the folder name as additional search criteria.
To do so you need at first reference from ITEMRevision to the ITEM (by items_tag) and then from the ITEM to the Folder (by Contents). Select the property object_name, which is the folder name.
In the querry builder it looks like this:
items_tag.Folder<-contents.object_name
THXSmiley Happy
Can you describe this part in more details?
Ok, I found waySmiley Happy
Hey,
How modify General... query to show standard revision form under specific folder?
Found link form Form search class:
