Query using wildcard / placeholders from Naming Rules
Customer wants to search all items with specific number of characters in item_id. This works fine with '?' wildcard character. However, like Naming Rule, we need to limit the criteria only to numbers and exclude any special characters matched against the placeholders. Ex: ?????? search criteria gives items with id 000256 and 000_41.
We need to exclude these unwanted special characters while matching with Item ID.
Like in Naming rules pattern, can we specify 'NNNNNN'  or '^[1-9]$'to match against only numbers?
Have anyone come across any solution?
We tried multiple combinations from the Naming rule patterns and think this could be a new ER!!
Re: Query using wildcard / placeholders from Naming Rules
Simple search will work.  Set the arguments for Item_ID as !=.  for example:
Item(ID) != *_*
Item(ID) = ????????
Richard Bennett
Richard Bennett
PLM Consultant
Prospect PLM Ltd
