Question on importing plmxml into TeamCenter
hello, everyone.
I am importing a PLMXML file into TC.
In the xml, there are some ProductRevision  nodes. Each node indicates which revision of the product shall be used in the bom line. For an example:
<ProductRevision  id="id201"  accessRefs="#id10" masterRef="#id101" subType="Design Part Revision"  revision="010"></ProductRevision>
My question is:
Is there any method to make TC automatically use the "Latest Wroking" or the "Latest Released" revision of the items in the BOM Lines? (so that I do not the ProductRevision  nodes.)
Re: Question on importing plmxml into TeamCenter
You can specify a revision rule in PLMXML import transfer mode ( as DBA in PLXML Export Import Administration application).
Is this what you were looking for?
Harish
sorry for my late reponse.
I think this is a feasible way. Thank you very much! I am a newcomer to TeamCenter.
Could you please tell me how to set this revision rule in detail?
