Red X on part in Visualization
Through Teamcenter I have a part that has a red X on it. I went on another machine using the same account and the part appears OK but on one machine I get the red X.
I'm assuming this has something to do with a local Teamcenter setting on the "bad" machine but I'm not sure what setting would cause this. Can someone help me figure this out?
Also what is "Has PMI"
Re: Red X on part in Visualization
Could this be that it is not pulling that part from teamcenter and maybe it's trying to pull a exported version of it off of the local machine??
Does the red X go away if you check in the part in Tc before sending it to Vis?
Evaluating: AW 3.4
There is nowhere to check in the part in TC...?
did a fresh TC install and that fixed it
