Released Drawings DWG Problem
Hello
When i release parts/drawings with multiple pages in teamcenter it creates the PDF normally (all sheets) but the DWG is created with only one page.
Does somebody know what's the problem?
I'm using Solid Edge 10 and Teamcenter 11.
Best Regards
Spake
Re: Released Drawings DWG Problem
@Spake - have you changed you SEACAD.ini file to include all sheets? By default it is set to only the first active sheet. This file needs to be changed on all SE machines that need this functionality. I would just copy the one I configured to all the others.
You need to select NEXT on the first screen to get to this 2nd page to change that setting.
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
