Do you mean
Reply
Solved! Go to solution
Remove Workflow Icon from Targets Upon Reject to Prevent 90 Statusing
Hi All,
I have used the "EPM-attach-related-objects" handler to add the workflow icon to item revisions within subfolders of my EO item revision (basically told the system that these sub-items are also targets of the workflow).  However, when an EO is rejected, the "90" status is applied to all of my newly assigned targets.  Upon rejection from an approver, how do I remove those assigned item revisions so they do not recieve a "90" status?
Brian
Solution
Solution
Accepted by topic author KNA
‎04-25-2017 06:41 AM
Re: Remove Workflow Icon from Targets Upon Reject to Prevent 90 Statusing
Hello Brian,
I recall an OOTB handler to remove workflow targets.
you may want to use the remove target handler before any of the epm calls that assign a status of 90.
I assume that the workflow template has a branching for EO Reject.
Harish
