Report builder results sorting
I have generated a report that displays the owning user, object name, original file name and file size for NX part files (UGMASTER, UGPART). I would like to sort the result based on file size (descending). The style sheet is a html type.
The file size and original file name are both compound properties, based on dataset, that were added and deployed through BMIDE.
I have tried the QRY_queryname_SortKeys/SortOrder preferences but to no avail.
Any help would be appreciated.
Manish
TeamCenter 9 2-tier
