Revise access permissions?
Siemens Creator
Currently on our system a user can only revise an object if they are a member of the Owning Group of the object but we'd like to make the permissions more open.
Does anyone know if this is done through Access Manager, and if so what ACL or Access Privilege is required as there is no specific Revise privilege. Or is there another way?
It's Teamcenter 12.0 .
Thanks.
Re: Revise access permissions?
As I recall, you need write access to the Item object to revise (because you have to add to the Item's list of revisions). That may just need the Working ACL to be updated (in Access Manager).
Tricia Crichton | Software Architect | SEAL PLM, Inc
