Revise available for statused Parts only
In Tc OOTB I can revise a part at any status. Is it possible to restrict te revising at a particular status only?
Example: After released status only?
How can it be done?
thanks
ProcessPLM
Re: Revise available for statused Parts only
It is doable from AM Rule tree.
You would have to configure access control entry (and revoke the copy access) for 'Has Status' condition in your tree. Set the value of 'Has Status' condition to your specific <release status>
Either you could explicitly revoke the copy access (less recommended) or leave it unset (usually recommended)
Harish
