Revision
Hi guys.
I have just created a new revision on a part using revise, I selected newmerical by mistake.
Is there a way to change this to alpha?
Re: Revision
Right click on Item Revision, go to edit properties there you will find option revision. change that revision to appropriate alpha revision, then click on save & Check-In.Untitled.png
Re: Revision
Hi Daxesh.
Thanks for the help.
I just have a couple more questions regarding the revision edit.
1. If I right click on the item and refresh it returns back to the previous revision format.
2. How do I get it to update the draft to the new revision format?
Re: Revision
Not sure what happened but it's ok now.
Re: Revision
may be
"DATASET_saveas_pattern" would resolve your 2nd question
Venny
