Rich Client Icon Size-Surface Pro 4
PLM World Member Genius PLM World Member Genius
To All:
I am currently trying to run the TC 10 Rich Client on a new MS Surface Pro 4. So far it all seems to work except with the extreme resolution the SP4 uses, the icons on the toolbars are so small I can barely even see them. Is there an easy way to change the sizes to something larger? I have yet to find a way to enlarge the toolbar icons.
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Budde Sheet Metal Works, Inc.
Windows 7 Professional x64 SP1
Solid Edge V20
NX11.0.1
TC10.1.5 32 GB RAM, nVIDIA Quadro K4200
7 REPLIES 7
Re: Rich Client Icon Size-Surface Pro 4
No, there is no way to increase the size of the icons :(
I do have filed an ER to get this functionality.
Employees of the customers, together we are strong ;)
Thank you Stefan, I found some documentation concerning 16x16 pixel sized icons and that was about it. They need to allow for this as that size in this day and age is insane. I'd love to jump onto that ER.
Attached is what I'm dealing with on a 12" screen with 2736x1824 resolution. The picture doesn't look half bad when it's full screen on my 27" desktop monitor, but when it's on a 12" Surface Pro screen at that resolution, you can't even see them. At least with my 40 something year old eyes...
Thanks again Stefan,
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Solid Edge V20
NX11.0.1
See ER#1873820 - ER: Toolbar icons are too small for high resolution displays with 120DPI setting ;)
With Windows 10 1703, you can try this :
Right clic on ...\portal\teamcenter.exe => properties => Compatibility, activate OVERIDE HIGH DPI SCALING BEHAVIOR SCALING PERFORM BY : SYSTEM
HEIA-FR, O.Mauron
What!? No longer a magnifying glass needed? I just tried your solution and it seems to have done a good job at scaling the icons up to a reasonable size.
Thank you!
Ryan
Ryan Gudorf
CAD/CAM Supervisor
Solid Edge V20
NX11.0.1
That was a great tip. It really helped out many users at our end straining their eyes. I think this should be posted in gtac as a solution.
This was awesome tip.
We also had the same issue with Surface pro and the steps solved the issue.
Thanks!!!
Yes this solution should be published on the GTAC site!!
