Search Several Items
Hi guys.
Is there any option to search several items on Teamcenter 9? I have a list of 54 items and would like to search all of them once only.
Jonny
Re: Search Several Items
Enter those item IDs in the field with SEMI-COLON as separator.
item-001;item-002;item-003
Typically ; is used as a separator, although you can change that using preferences.
Thanks and Regards
Yogesh Fegade
It works fine, but when I select multiple items, only the firt one open.
How can I open all of them?
What do you mean by "Open"? When you Open an Item in Teamcenter, Teamcenter will create new tab in My Teamcenter application (left panel) and display the Item/Revision information there.
I am able to select 3 items and Open all of them in their respective tabs.
Thanks and Regards
Yogesh Fegade
Take a look at the attached picture.When I select 8 items, it just open the first one into the left tab.
How can I open all of selected one?
I see, you are using the quick search bar. Use search panel and execute "Item..." saved query.
Thanks and Regards
Yogesh Fegade
Great! Thank you so much and have a nice day!!!
Hi
Is there a vba macro to open multiple item ids in teamcenter from excel and get the bbox dimension for each item id  and paste to the same excel .
Joseph
No
Evaluating: AW 3.4
