Do you mean
Reply
Solved! Go to solution
Segmentation fault
I am getting a segmentation fault in the following function:
vector<tag_t> GetGroupRole_Tags(vector<string> groupRole_Info, string tag_type)
                vector<tag_t> v_tags;
                for (int i = 0; i < groupRole_Info.size(); i++)
                               vector<string> a = split( groupRole_Info[i], '/' );     // groupRole_Info[i] = Development/Developer
                               cout << "GROUP: " << a[0] << " ROLE: " << a[1] << endl;
                               const char *group_name = a[0].c_str();     //stores: Development
                               const char *role_name = a[1].c_str();        //stores: Developer
                               const char *user_id = NULL;
                               int *member_found = 0;
                               tag_t *output_tag;
                               SA_find_groupmember_by_rolename(role_name, group_name, user_id, member_found, &output_tag);
                return v_tags;
The error is on the line:
Can anyone please help me debug it. Thanks.
Solution
Solution
Accepted by topic author Dev2
‎04-07-2017 01:41 AM
Re: Segmentation fault
I have not compiled or linked this code, but I would have done something like this.
Let us know if it sorts out the segmentation fault.
Harish
char *group_name = NULL;
char *role_name = NULL;
int member_found = 0;
tag_t *output_tag = NULL;
for (int i = 0; i < groupRole_Info.size(); i++) { vector<string> a = split( groupRole_Info[i], '/' ); // groupRole_Info[i] = Development/Developer cout << "GROUP: " << a[0] << " ROLE: " << a[1] << endl;
if (tc_strcmp(a[0].c_str(),"")!= 0) {
group_name = (char *)a[0].c_str(); //stores: Development
if (tc_strcmp(a[1].c_str(),"")!=0) {
role_name = (char *)a[1].c_str(); //stores: Developer
} SA_find_groupmember_by_rolename(role_name, group_name, user_id, &member_found, &output_tag); } return v_tags; }
the segmentation fault has been resolved. The problem was with the following output parameter:
Thank you for your help.
