Sending Multiple Item Revisions to their Own Individual Workflow
Hello experts,
Currently, we have a workflow that sends an Item Revision through its own process. This same workflow could take multiple Item Revisions and send all through a single process. (not desired)
I was wondering if there was a way to select multiple Item Revisions at once and start a process so that each Item Revision would get its own independent workflow.
1 REPLY 1
Re: Sending Multiple Item Revisions to their Own Individual Workflow
Hello Curtis,
Try the EPM-create-sub-process handler, with the -multiple_processes argument.  Essentially you would have one spawning workflow (where the user has selected multiple ItemRevs).  That workflow would immediately use this handler to spawn independent child processes for each ItemRev, and then it would end.
Don
