Setting Effectivity values via SOA
Good day everybody, good night everybodybodyelse.
I am trying to set effectivity values for an item remotely using SOA, initially my plan was:
1) Obtain the revision
2) Obtain the StatusRelease Object I need
3) set its properties, specially its effectivity_text directly.
The property is shown in the Properties window of the StatusRelease element from RAC. So the plan looked simple, obtain the Object, set its "effectivity_text" to the desired value and we are done. 1 and 2 work as expected but I am obtaining no properties at all in the ReleaseStatus object no matter the policy I use. Somehow effectivity related values are private to the class and cannot be accessed directly.
Any idea of how to set the effectivity values of a StatusRelease object from SOA code? Is EffectivityManagement service capable of doing it? Any hint?
Re: Setting Effectivity values via SOA
Exception in thread "main" foran.lib.tc.impl.teamcenter.exceptions.TCOperationException: Error Msg.:
Property Effectivity is not modifiable.
Error Val.: Property Effectivity is not modifiable.
