Show relations in Teamcenter for NX parts that are defined as "Part is reference only" in NX drawing
In NX drawings, you can define a view of a part that comes not from the same assembly of the drawing.
Base View --> Part --> Open - Select any part in Teamcenter - you get a new view and a part that is "Part is reference only"
I would like to see this relation to this part in Teamcenter, because if someone modify  the "Part is reference only" then will be also change my drawing.Part_is_reference_only.pngPart_is_reference_only_01.png
Greetings from Hamburg
Andreas
Re: Show relations in Teamcenter for NX parts that are defined as "Part is reference only"
Andreas,
You have to find the real relation, first.
Referenced_POM.jpgPOM References
Then you have to add this relation to the UGPART in the BMIDE and deploy.
Add_Relation.jpgAdd relation to UGPART
And last, you have to modify the TC preference:
Add_Preferences.jpgModify TC preference
Result:
Attila Szepesi, Application Engineer, graphIT Ltd.
Production: NX12.0.2 | TcUA 11.3
Development: VB.NET, C# Testing: NX--
Andreas,
The video:
(view in My Videos)
