Simple BOM compare
Honored Contributor
Honored Contributor
For the not so TC savy users, is there a simple way to compare the BOM of two assemblies? could be different Items or Item Revisions.
-Dave
NX 11 testing NX1847+ | Teamcenter 11 | Windows 10
3 REPLIES 3
Re: Simple BOM compare
Honored Contributor
Honored Contributor
Sending one to Structure Manager, splitting the window, and then sending the second to structure Manager seems to work.
Any better/easier options?
-Dave
You've nailed the process. That's how it's done. You can compare rev A to rev B or Item X BOM to Item Y BOM using that method.
Evaluating: AW 3.4
AFter that go to tools--->Compare---> you can select the type of Mode you want
