Solid Edge Property Manager
In my unmanaged days, I used property manager in Solid Edge to modify custom properties of my draft files.  My title block text was linked to custom properties I have created.  Example: I could modify my revision table to add issue release statuses, update dates, update names, etc.  I was wondering if there is a similar feature in Teamcenter?  I am trying to find a way where I can update statuses or dates without having to open each draft individually and change them one by one.  When you have 50-100 draft files, check-in/out takes a long time.
Re: Solid Edge Property Manager
You must make new attributes mapping:
Dataset_Status : last_release_status.name /master=iman /description=Status Datasetu
Dataset_Status_Date : date_released /master=iman /description=Data statusu datasetu
For object name default atrributes for SEEC are "Project Name".
Next you must use this attributes in yours draft templates.
SE ST9 + TC 10.1.7
