Starting the dispatcher components
Hi All,
Do i need a follow a specific order when starting the dispatcher components like Scheduler, Module and then Dispatcher client or we can start in any order we want.
Syed
Re: Starting the dispatcher components
Its best to start Scheduler first then Module and Dispatcher Client last. Shutdown order is DC, Module then Scheduler.
Evaluating: AW 3.4
thanks @RandyEllsworth.
