Summary is not configured properly error message in Web Client
Hello
Today we have noticed an issue relating to Summary.  In our RAC configuration the Summary view appears however it looks completely different from before. Within the Web Client, we receive a message from the webpage to say Summary is not configured correctly.
This message/error is seen when I select a Document Item/Revision.  I have attached pictures from our Development environment. This does not happen in Production. I have a screen shot of this too attached.
Re: Summary is not configured properly error message in Web Client
When a custom stylesheet cannot be displayed (not downloaded) then the viewer reverts to showing properties. You probably have an issue with the transientVolume. On the enterprise server (running server manager) run backup_xmlinfo. Compare the values in backup.xml with the FMS Master and Tc preferences. Any differences will need to be resolved. Edits to FMS will require a FSC service restart. Edits to Tc prefs will require a restart of the rich client. Once completed then rerun backup_xmlinfo again to ensure that values are the same.
Evaluating: AW 3.4
This is now resolved. We tightened up the definition of FMS server ip address in the FMS master file. Restarted the FMS services.
Thanks for your help.
