Symbol
Hi Guys.
I have a symbol and I do not know what it means.
It is a circle with a white square top & bottom, a green square on right and orange square on the left.
What does this mean?
I think it is stopping me deleting the item.
Re: Symbol
Meaning of symbol is, that item revision is attached to perticular workflow.
Re: Symbol
You can use cut option istead of delete.
Re: Symbol
Cheers Daxesh.
How do I find out which one?
That revision isn't in any assembly and I want to delete it but can't.
Re: Symbol
It means the object has been added to a workflow and is "in-process" meaning that it has not been released yet. You have to find the workflow (job) it is in by performing a "Where Referenced" on the object. Then you can select it and see where in the workflow it is and who's task list it is in.
Evaluating: AW 3.4
