Syntax for epm-set-property for LOV property
I am having problem getting my workflow to change the value of an object property that uses a LOV.
In my workflow, I am using a Do Task with the epm-set-property on complete with the argument:value combinations below.
epm-set-prop
Argument:Values
-property:MyProp
-value:MyValue1
-from_lov:MyProp_LOV
-to_attach:TARGET
- bypass
This is not setting the MyProp and throwing an LOV error for the workflow.
Any guidance on what I may be doing wrong.
Re: Syntax for epm-set-property for LOV property
Good afternoon, I think that the likelihood that you can be helped will be greater if you provide an example of your lov.
