TC drawing cannot be checked in
I have one drawing and one 3D have been checked out, but TC said the access is denied when I was trying to check in. the operation failed on one or more of the selected objects.
How can i check both of them in
Re: TC drawing cannot be checked in
Did you change your group after checking this out? Are you using projects? You aren't showing enough information below to figure this out. Look at your syslog to see more information on the error.
Jamie Griffis
Mercury Digital Services
Jamie Griffis | Teamcenter Architect | Applied CAx, LLC
@jamieGriffis,
thanks for you reply, I am sure i never changed the group, the drawing and the part are being assigned to the project.
As below figure, we can see only the drawing is being checked out, but the sheer of the drawing is normal.
Could you kindly tell me how to find the syslog, my TC installs in the remote server
