TC10 patch update to 10.1.5 error
Builder
Builder
hello Team,
am trying to update TC10 to patch version 10.1.5
am unable to proceed further
its showing zip file is corrupt am unable to get which zip file
attached is the screenshot and log information.
Core paths
D:\TC10
C:\Program Files\Siemens\Teamcenter10\install
Browsed paths
None
Patching Information
201904150337: D:\TC10\Tc10.1.5.1_wntx64\wntx64
Processing patch.xml
Time: Mon Apr 15 06:04:50 CDT 2019
Loading patch filer
Loading D:\TC10\Tc10.1.5.1_wntx64\wntx64\install\patch.xml
Executing [echo %PATH%]
Executing [set PATH=%FMS_HOME%\lib;%PATH%]
Executing ["C:\PROGRA~1\Siemens\TEAMCE~1\tccs\bin\fccstat.exe" -kill]
Output from command: "C:\PROGRA~1\Siemens\TEAMCE~1\tccs\bin\fccstat.exe" -kill
fccstat -kill: FCC Offline.
command_exit=-3001
Exit Status -3001, elapsed time 0:00:00
Running com.teamcenter.install.tem.patch.Patch
Restoring configured files
Time: Mon Apr 15 06:05:00 CDT 2019
Executing [echo n | "C:\Program Files\Siemens\Teamcenter10\install\install\unzip" -Co -d"C:\Program Files\Siemens\Teamcenter10" "C:\Program Files\Siemens\Teamcenter10" "portal/registry/genregxml.bat"]
An error occurred during execution. Stack trace follows...
com.teamcenter.install.tem.patch.Patch.restoreConfiguredFiles(Patch.java:712)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
java.lang.reflect.Method.invoke(Unknown Source)
com.teamcenter.install.tem.tasks.JavaTask.execute(JavaTask.java:209)
com.teamcenter.install.tem.tasks.Task.execute(Task.java:135)
com.teamcenter.install.tem.tasks.blocks.CodeBlock.execute(CodeBlock.java:201)
com.teamcenter.install.tem.tasks.blocks.CodeBlock.execute(CodeBlock.java:181)
com.teamcenter.install.tem.patch.Patch.begin(Patch.java:270)
com.teamcenter.install.tem.director.actions.PatchingAction.execute(PatchingAction.java:47)
com.teamcenter.install.tem.director.DirectorScript.execute(DirectorScript.java:143)
com.teamcenter.install.tem.director.Director.run(Director.java:120)
java.lang.Thread.run(Unknown Source)
4 REPLIES 4
Re: TC10 patch update to 10.1.5 error
Siemens Legend Siemens Legend
Siemens Legend
is this something you get on the server or client?
the latest TC_ROOT\install\install_updater_<timestamp>.log would be interesting to see
Builder
Builder
@MarkusK
am getting this on the server.
could help me know why its unable to update patch.
Time: Mon Apr 15 21:12:11 CDT 2019
*** CANCELLED
Installation interrupted due the following reason:
UPDATE MANAGER FAILURE: PatchingAction: The zip file is corrupt
Time: Mon Apr 15 21:12:16 CDT 2019
CommentStore
An internal error occured which has caused processing to stop.
Severity: 1 (Severe)
Copying file C:\Program Files\Siemens\Teamcenter10\install\configuration.xml to C:\Program Files\Siemens\Teamcenter10\install\configuration1904152112.xml
Siemens Legend
I'd expect somewhere a zip file on this line:
but I am missing it here (no wonder it says later that the zip file is corrupt)...
In your case I'd raise an IR at GTAC
@MarkusK is correct. Both zip.exe and unzip.exe should be in TC_ROOT\install\install\ for the patch to work. Check that virus scanning isn't interfering?
Evaluating: AW 3.4
