TCXML documentation
Siemens Creator
hello,
does anybody have or know where I can find some documentation about TCXML?
I want to see if it's posible to execute the export by a command line and in the closure rule write something like:
Class.ItemRevision:Class.Dataset: and in the condition say: SecondaryObject.nameOfVariagle=$valuecomingFromCommandLine
I want to export only the datasets with a certain value in a dataset attribute. So the extraction is different everytime.
Anybody knows if this is posible??
thank you!!!
Re: TCXML documentation
depending on your version of TC, PLM XML/TC XML Export Import Administration:
https://docs.plm.automation.siemens.com/data_services/resources/tc/11.5/PDF/tdoc/en_US/pdf/plm_expor...
Rich
Richard Bennett
Prospect PLM
