Team center EngineeringUtilityException:POM002
I'm trying to install Teamcenter11 on Windows server 2012r2 , but I got this exception. I already installed SQL server 2012 , JAVA  and activate the license with PLMLicenseServer.
An error has occurred during the operation.  Review the problem description and suggested actions.  If a failure requires some input, the fields will be displayed below.  Click the following log file to some technical information which may be useful in troubleshooting the issue.
Engineering Utility Failure
EngineeringUtilityException: POM002
Description
One of the Teamcenter utilities has failed.
Additional Information
The command returned a value of 1
Could you please help me?
Re: Team center EngineeringUtilityException:POM002
Review the tc_install.log mentioned in the screen shot for more information.
Evaluating: AW 3.4
Check the Version of the License File and License Server. Looks like make_user is failing because of that.
PLM Consultant
