04-20-2015 09:51 AM
Hi, I have a problem with revising an Item or want to have suggestions how to do this. I am using C# or sometimes Java and the SOA interface by Simens.
In my application I want to make a new revision, thats no problem. In the new Revision I want to delete all or parts of my datasets (links). How can I delete the relation that follows from the original revision? I have not found anything regarding this operation i TeamCenter. Anyone have an idea?
best regard
Jonas
05-28-2015 01:35 PM
If you want to remove those datasets from all "new" revisions of the item type, then why don't you use deep copy rules? You can set them up in BMIDE.
07-14-2015 06:53 AM
you can also set deep copy rules in your program with ReviseInfo.deepCopyInfo if this behavior you want is specific to this application.
/Frank
