Teamcenter 10.1 and Jboss Configuration issues.
Dear all,
I have installed Teamcenter 10.1 Corporate server on system and i want to access this Enterprise Tier from another system with TC 4T. For this, we need Java EE web tier installation which also i have installed. But when i paste my .EAR file in \Jboss\jboss-as-7.1.0.Final\standalone\deployments and Run Standalone.bat from \Desktop\Jboss\jboss-as-7.1.0.Final\bin  deployment is failing. Please suggest step wise instalaltion of same.
Below is error on Jboss console:
{"JBAS014653: Composite operation failed and was rolled back. Steps that failed:" => {"Operation step-2" => {"JBAS014671: Failed services" => {"jboss.ra.deployer.\"TBMROOT.ear#JETIAdapter\"" => "org.jboss.msc.service.StartException in service jboss.ra.deployer.\"TBMROOT.ear#JETIAdapter\": JBAS010446: Failed to start RA deployment [TBMROOT.ear#JETIAdapter]"},"JBAS014771: Services with missing/unavailable dependencies" => ["jboss.naming.context.java.module.TBMROOT.TBMROOT.env.ejb.Gatewayjboss.naming.context.java.global.tc.JETIGateway-ejb.\"Gateway!com.teamcenter.jeti.ejb.GatewayHome\"Missing[jboss.naming.context.java.module.TBMROOT.TBMROOT.env.ejb.Gatewayjboss.naming.context.java.global.tc.JETIGateway-ejb.\"Gateway!com.teamcenter.jeti.ejb.GatewayHome\"]","jboss.naming.context.java.comp.TBMROOT.JETIGateway-ejb.Gateway.env.jca.JETI.Adapterjboss.naming.context.java.jboss.resources.jca.JETI.AdapterMissing[jboss.naming.context.java.comp.TBMROOT.JETIGateway-ejb.Gateway.env.jca.JETI.Adapterjboss.naming.context.java.jboss.resources.jca.JETI.Adapter]"]}}}
8 REPLIES 8
Re: Teamcenter 10.1 and Jboss Configuration issues.
Are you adding -b 0.0.0.0 to the launch command?
What JRE/JDK version needed for installation JBoss8(WildFly)? JDK 1.7.25 as I see not supported
When on 10.1, I would stick to jboss-as-7.1.0.Final and JAVA 7.
For TC 10 JDK 1.7.25 is minimum recommended version. I suppose some update for 1.7 needed or 1.8.
Where I can found this setting in Jboss(WildFly) 7.1.0 ? Or other settings and config files are using in last version of JBoss?
As far as I remember, JBoss AS 7 / TC10.1 were not working fine under JAVA 8. I recommend you to check Siemens guide to setup the application server properly. Once done, use -b 0.0.0.0 to launch JBoss.
I installed jboss 7.1.1 instead of 7.1.0,used JDK 1.7 instead of 1.8(tc10 also use jdk 1.7), make some tuning from corresponding PDF from GTAC (jboss 7.1.0 tuning guide) and thin client now works fine.
That's good news.
