Teamcenter 11 and Master Model Support
Hello,  This is a general question that hopefully someone can confirm.  I have heard that with Teamcenter 11 Siemens has choosen that all Items that are created for NX CAD must follow Master Model approach.  Meaning, when you create a UGMaster Dataset for the 3D data, you will be forced to create a UGPart for the 2D drawing.  Our current practice is that the UGMaster houses 3D data and 2D drawing.  Tryign to plan for upgrade, and this may be a big challenge.
Thank you,  Aaron Ruple
Aaron Ruple
Navistar Inc.
6 REPLIES 6
Re: Teamcenter 11 and Master Model Support
Hi Aaron, I'm running Tc11.2 w/NX10.0.3 and have not experienced this issue. If they changed the default behavior then it would be listed in the Release Notes along with the work-around (change a property) to revert the behavior for a period of time (couple of releases). If you don't see anything listed in the release notes then I'm pretty confident that change is false.
Evaluating: AW 3.4
Hi Aaron,
Nothing has changed. I'd be curious to know where you got this information.
Regards, Ben
Hello Randy,
Yah, I browsed those areas but couldn't find anything specific for that subject.  I have heard this 2nd hand and was somewhat shocked, so wanted to find some facts before I followed up.
Aaron
Aaron Ruple
Navistar Inc.
Hello Ben,  Supposedly it was mentioned by our Siemens technical support team that did an onsite overview of latest versions.  I wasn't here for the sessions, so I was hoping something was just misunderstood by our team and/or not clearly defined by Siemens.  As Randy noted, a change like this is fairly large and we would have heard/read details versions ago.  Granted, we are multiple versions behind.  I found in NX documentation that it is still supported, so found it odd that it would have been restricted in Teamcenter.
Aaron Ruple
Navistar Inc.
Hi Aaron,
I have confirmation from the Product Manager that nothing has changed.
Regards, Ben
Thank you Ben - I appreciate. Aaron
Aaron Ruple
Navistar Inc.
