Teamcenter 11 started to stuck on "Retrieving image for xxxxxxx-part" ?
Hello ( Teamcenter 11 (11.4(20171201.00)) 64-bit )
Teamcenter started to stuck on "Retrieving image for xxxxxxx-part" ?
- How to solve it ?
- It started behaving like this multiple times.
Re: Teamcenter 11 started to stuck on "Retrieving image for xxxxxxx-part" ?
I exited the TC11 and tried to log in and greeted with below error.
  • This Retrieving Image-stuck has happened 4x times already each with different parts.
  • Restarting Windows 10 works and TC resets to normal and works for a while until next Retrieving Image-error happens.
Delete contents of %temp% folder
Delete %USERPROFILE%\Siemens
Delete %USERPROFILE%\Teamcenter
Delete %USERPROFILE%\fcc* files
Once done, set FMS home to correct path in system environment varible. Create a batch file with below and run it.
@echo
%FMS_HOME%\bin\fccstat.exe -restart
%FMS_HOME%\bin\fccstat.exe -clear
echo Successful
Pause
This will start FCC, try to launch TC after this.
Br,
Rupesh
