Teamcenter 9.1 integration for Creo
Builder
Builder
Hi.
Is there any integration module for Teamcenter 9.1 and PTC Creo or Pro-Engineering solutions.
I have many ProE CAD files and I it would be nice to having integration between them.
8 REPLIES 8
Re: Teamcenter 9.1 integration for Creo
You can refer the documentation link 'Intergrations & Solutions'. There you will find the Administration Guide, Installation Guide for Dispatcher Client, Installation Guide and User guide for ProEngineer/Creo.
Yes. There is 'Teamcenter integration for Pro/Engineer Version 9.1.0' (can be referred to as iPEM 9.1.0) for Teamcenter 9.1.2.7 and above MPs/Patches.
These are iPEM 9.1.0 pre-requisites on PTC:
- Wildfire 4.0 date code M210 or later
- Wildfire 5.0 (CREO Elements) date code M200 or later
- CREO Parametric 1.0 date code M050 or later.
- CREO Parametric 2.0 date code M070 or later.
Harish
I started installing integration and  got below error. how to fix? any suggestion.
Venny
Check that your version of Java is compatible and that JAVA_HOME is set correctly.
Evaluating: AW 3.4
All
Good Morning.
I installed the integration and creo. it works fine. But I noted that all the item types and custom items are not available. only one "Item" is there. how to get the all items and custom items
I think you need to add the types to ipem.xml. There are a few other files that need to be modified to and you'll need to import the mapping. Read the Installation and Admin guides provided in the integration software.
Evaluating: AW 3.4
Randy Thanks. I check the documents and am not yet clear how to modify. let me explore more
We have structure manager in TC and Solid edge integration. is there anything similar to Structure manager in TC and Creo integration
